Questions concerning changes needed after overboring
Old Nov 19, 2002 | 03:40 AM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
The 92z I just got has a 350 bored over to 357 - I think that's a negligible difference, but I'm not exactly an expert, so I was wondering if there are any things I need to change to make it run optimally, like fuel pump, injectors, prom, or anything? Obviously, I know there are always things to make the thing more powerful, I'm asking what needs to be done to make it run right - they guy I bought it from suggested that the fuel pump or injectors may be inadequate, but 350 to 357 is such a small change, was wondering what you guys think.
Old Nov 19, 2002 | 10:11 AM
Desert86Roc's Avatar
No changes necessary as long as you kept it stock. Anyone can benefit from PROM changes, even on a stock motor.
Hopefully you put a better cam (or anything better than stock) in it when it was rebuilt. Otherwise, it wouldnt be worth all the trouble of a rebuild.
Old Nov 19, 2002 | 01:59 PM
jamesbob02's Avatar
Car: 92 Z28
I wasn't the one who did the rebuild, it was the previous owner, and I think he probably used the same cam, he did say that he used good parts tho, like high quality pistons and such, but I doubt he got a better crank or cam.
However, I've been thinking recently about doing a cam swap myself, I'm open to any recommendations for my setup. Thanks!
MustangBeater20
Oct 29, 2022 09:20 PM
IROCZ1989
Jan 24, 2016 03:55 PM
redmaroz
Aug 16, 2015 11:40 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
