Should I be able to feel the injector firing?
Old Nov 22, 2002 | 09:56 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
When I was troubleshooting my false lean condition, I was examining the fuel injectors. I was able to 'feel' 7 injectors clicking when I touched them but #4 I could not. Should I assume that the injector is bad? The injectors are Accel and replaced 8k ago. Plus, my new motor is scheduled to go in next week, would it be a bad idea to run it if the injector is bad?
Old Nov 23, 2002 | 12:47 AM
gflo383's Avatar
Car: IROC Z
Engine: 355 MINIram w/boost
if the injector is not firing, it would be a bad idea to run the engine, a lean mixture is very dangerous, and could cost alot of money. what i would do is hook up a noid light to that #4 injector you said you dont think was firing, and see if its actually getting power to it, if not, then theres a short somewhere along the way, if so, its prolly a bad injector, or the plug is some how corroded and not making a connection....
Old Nov 23, 2002 | 07:22 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Try tapping the injector "lightly" with a wrench a few times and try to feel it again. You can feel a slight tick like you said of the others. This worked for me when I had 2 cyl. misfiring. This can happen when the car has sat for awhile or the injectors have been cleaned recently. Sounds like a sticky injector. Hope this helps ya???
Old Nov 23, 2002 | 08:11 PM
I used a long screwdriver as a stethascope(sp?) and I could hear it clicking then, so it is firing. I wonder why I can't feel that one tho.
Old Nov 23, 2002 | 10:55 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
If it is sticking you need to give it a good little tap a few times to try to losen it up.
Old Nov 23, 2002 | 11:24 PM
vortechLT1's Avatar
after I dropped the LT1 in my car I couldnt get it to start, after trying many different things I soaked the injectors in valvoline synpower carb & choke cleaner, after doing that it started and ran fine. (just a thought)
9192camaro
16
Feb 3, 2019 12:21 AM
Justin92GTA
Aug 27, 2015 11:16 PM
Jae992
Aug 27, 2015 09:07 AM
86IROC112
Aug 21, 2015 07:20 PM
flash2042
Exterior Parts Wanted
Aug 7, 2015 05:58 PM
