why doesnt my fuel pump turn off...
Old Nov 25, 2002 | 01:30 PM
xanax's Avatar
for some reason my fuel pump continues to run even after the car is turned off, the relay is unplugged, and the computer is disconnected. the only way i can get it to stop is to get up under the car and disconnect the wires running into the pump. anyone have an idea?
Old Nov 25, 2002 | 03:24 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: why doesnt my fuel pump turn off...
There is a fuel pump relay bypass that will
power the pump if it senses oil pressure.
It may be bad. It can be located on the
back top of the motor (end rail) or over the
oil filter housing..
mike
Old Nov 27, 2002 | 08:26 AM
xanax's Avatar
i guess thats why my pressure gauge is maxed out past the highest reading all the time. makes sence. thanks for the help...
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
9192camaro
16
Feb 3, 2019 12:21 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
