ECM questions
Old Nov 27, 2002 | 04:10 PM
IROC_5796's Avatar
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
ECM questions
I just found out I can use a 730 ecm from other cars not just 90-92 camaros for converting to speed density. If possible could anyone elaberate on this. which cars to look for? with what engine size? which prom chip? does it use the same as these other cars or do I need one for the camaro? how can these other cars use the same ECM? I really need more information, so any of you guys can help it would much appreciated. thanx
Old Nov 27, 2002 | 05:36 PM
Z_Ghost's Avatar
Look for a late 80s to early 90s Lumina/Corsica or Berretta. Also Pontiac Tempests and virtually all FWD V6 MPFI car from the late 80s to the early 90s. Just avoid "W"s.
The Lumina does not have a VATS module as standard equipment. They probably have the "VATS" disabled in the V6 eprom.
To get VATS, you need the the VATS module, the ignition and the key. You'll only find that in a Corvette or an F-body of that era.
Lastly, the 4th digit of the VIN is the car model (avoid "W"s) and the 8th digit is the engine code.
You will need the prom chip and memcal for a Camaro.
Old Nov 27, 2002 | 11:28 PM
IROC_5796's Avatar
thanks, exactly what i was looking for, do i really need the VATS, everything is going into my 82 camaro, im useing all the wireing and all that junk out of a 88 IROC. if I get a ecm that doesnt have the vats built into it is that a good thing?
Old Nov 27, 2002 | 11:50 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
Yes, that is a good thing. The vats in programmed onto the prom, not the ECM. All 730 ECM's are speed density. Whichever one you get will have to have a prom for your engine type. You will also need a lot more junk to go with the 88 harness. The most expensive items will be the O2 sensor, a different distributor (at least a different module) and a speed feedback module to mount on the transmission.
Old Nov 28, 2002 | 10:42 AM
IROC_5796's Avatar
do I ned a different type of distributer? or just the module for it? if its just the module where is it? and is it expensive? if its the distributer, why do I need a different one? I thought I would just need an external mounted coil distributer.
what is the module needed for the transmission? is it a factory piece that I need or do I have to go to an aftermarket company?
sorry for all the questions, I bought a book TPI swappers guide and it doesnt talk about any of these things.
Old Nov 28, 2002 | 11:14 PM
72LT1VETTE's Avatar
Engine: 350 HO
Axle/Gears: 336
You can use the distributor from the 88 with it's module (the red thing with pin connectors on the side of the distributor). Go to the link below (GM ECM's) and select the 1227165 ECM. Follow the links at bottom of page. Print the pages. This is the harness you have. Go back to main page. Go to 1227730/1227727 page. The 1227727 was an underhood speed density ECM for 89 Grand Prix Turbo and 90 Vette. You will also see all the model vehicles the 730 ECM's were in. Some were TBI most were MPFI (TPI). Print the pages for the 90-91 "F" body. You will have to get connectors for the 730 or 727 and modify your harness to work. There are pages here in Tech help to make it easier. A sending unit will have to be mounted between your speedo cable and transmission gear for speed sensing. That part number I believe is in Tech help. It is aftermarket. GM ECM's Email John at weg1192@aol.com. He made my harness. Maybe he will send you drawings and part numbers. Also, I'm not sure if you will need a different driven gear on the distributor shaft for the 82 model..
ezobens
Aug 19, 2015 10:29 PM
355tpipickup
Aug 19, 2015 10:02 PM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 10, 2015 08:42 AM
