Hunting Idle
Old Dec 1, 2002 | 01:21 PM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
Axle/Gears: 3.23 for now
Hunting Idle
I have a 91 Z28 355 cid auto. This problem just started. When I stop at a traffic light The car idles fine for a few seconds then she will hunt from 500->800rpms. I have to touch the gas to level the rpms off. Then she runs nice for 30 seconds then hunts again. The car drives good and doesnt seem to miss at all. This only happens in the drive gears and not in park or neutral. Any ideas?
Old Dec 2, 2002 | 10:49 AM
NJITIROC's Avatar
Car: 1989 IROC-Z
seems to be somethin that plagues all thirdgens for the most part. im interested in the answer as mine does it too.
fuel, electrical are all up to date and functioning properly, no vacuum leaks seem to be there. so i am confused.
Old Dec 2, 2002 | 11:02 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Dirty IAC normally on a stock car..
The Stall saver code sometimes has issues too. On my car I had to raise the idle to 800rpm to compensate for the cam.. (in prom).
Try cleaning the IAC..
Old Dec 2, 2002 | 11:25 AM
NJITIROC's Avatar
Car: 1989 IROC-Z
any recommended method to cleaning the IAC?
does it have to be removed to clean or can I do it right on the engine?
thanks alot!
thats one thing i havent tried doing to fix the problem
Old Dec 2, 2002 | 01:04 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Yeah gotta removet he throttle body, dissasemble the bottom section, and clean it with carb cleaner..
-- Joe
Old Dec 2, 2002 | 01:07 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
They're probably right but when is the last time you replaced your O2 sensor?
Old Dec 2, 2002 | 01:48 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
well not since ive had the car no replacement
how much do they cost?
Old Dec 2, 2002 | 01:52 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
In the $30 range I believe
Old Dec 2, 2002 | 01:56 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
thanks alot Dan!
Old Dec 2, 2002 | 08:54 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Well. That is possible.. At least after the car warms up anyway..
Old Dec 2, 2002 | 10:28 PM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
My car is far from stock and this problem only just started and is intermitant. Thanks for the advice! I will clean the IAC when I install my Holley AFPR and will put in a new O2 sensor just as a maintenance thing. Thanks for the input and I will let you know what happens.
Old Dec 2, 2002 | 10:30 PM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
Hey Anesthes, Got pics? Would love to see that car...
Old Dec 3, 2002 | 06:51 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I've got some old ones..
http://members.cisdi.com/~anesthes/projects/pix/
Whats different is, the gauges are in a a-pillar pod now, the engine bay is cleaned up big time, different valve covers (M/T alum), formula wheels, and a few other cosmetics..
Thanks!
-- Joe
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
BDR
Nov 7, 2015 03:05 PM
89newfun
Sep 16, 2015 09:28 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
