86 T/A and MAF
Old Dec 4, 2002 | 06:49 PM
Sailor77's Avatar
86 T/A and MAF
Hey this is my first post and I am sure to create a heated discusison over SD and MAF, which I don't want to do. Here is my situation
1986 T/A with 305 TPI. The intake, injectors, and TPI are all 350.
I can't seem to keep a MAF in the car. It burns outs extremely quickly. I get no codes until it is gone.
I have tried putting resistors and diodes in line hoping to stop the MAF frying, but as the ohms are so low and a butt connector has 4 ohms of resistance, you see my problem.
Is there anything I can do to keep the MAF from burning out? Should I change to SD. I don[t plan on making any more engine modifications, and besides the 5.7 TPI she is stock.
Old Dec 4, 2002 | 09:10 PM
ROC-Z's Avatar
You have a wiring problem, or the ECM is bad.
My '86 IROC-Z is in the shop for the MAF & burn-off circuit to be rewired. Since the wires were shorted out to the chassis, it damaged my ECM also- so I had to buy a new ECM.
Old Dec 4, 2002 | 10:37 PM
Guest
Guest
Posts: n/a
Check the wiring near the connector. I have seen more than a few single fan setups eat the MAF wiring.
Mark_ZZ3
May 24, 2018 01:02 PM
2012sergen11
Oct 13, 2015 07:38 PM
racereese
Oct 3, 2015 03:46 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
