Fuel pressure setting
Old Dec 6, 2002 | 09:21 AM
dd85T/A's Avatar
Car: 85 T/A
When measuring the FP you disconnect the vacuum line right?
How do you know when its adjusted correctly? Like say 45-47 or 47-49lbs. Is there some way to tell, BLM'S or something using a scanner? How do you know for example 47lbs is better than 45lbs or 42 or 52? Thanks for your help.
Old Dec 6, 2002 | 12:29 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
I tested mine on a dyno. I tried it at the track but there are too many variables.
Old Dec 9, 2002 | 01:37 PM
dd85T/A's Avatar
Car: 85 T/A
ttt
Old Dec 9, 2002 | 03:22 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
You only want to set the fuel pressure to what gives you the best WOT performance, like on a dyno as DannyT said or at the dragstrip.
For cruising around, a fuel pressure change will result in a change in the BLM, after 15 to 20 minutes the BLM value will stabilize.
If we could count on our inaccurate O2 sensors, I would find the fuel pressure that gave me 880 to 890mV from the O2 sensor when at WOT.
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
