High performance chip
Old Dec 6, 2002 | 10:32 PM
smooth_11_26_99's Avatar
i have been hearing a lot of talk about a high performance chip you can buy, i have an 86 camaro with tpi 305 just wondering would it be worth buying and is their a big difference
Old Dec 6, 2002 | 10:40 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: High performance chip
See the "sticky" at the top of this forum..
Also check out the PROM board, and the
plethora of tech articles...
stop listening to talk, and just do a little
reading... 8-)
mike
Old Dec 7, 2002 | 10:32 AM
to mike
well mike i just got my camaro not to long ago i just ask a simple question which required a simple answer no need to be a dick
Old Dec 7, 2002 | 10:41 AM
kevinc's Avatar
Car: 1982 Z28
Read before writing. Listen before asking.
Simple enough?
Old Dec 7, 2002 | 10:55 AM
to kevin
well another as hole maybe you should listen i just got the car and i was listening to people and i would not know a good magazine to read or what ever the hell you were talking about to even read rude freak, sorry for posting in the wrong place *** hole
Old Dec 7, 2002 | 11:21 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
are you two done?
smooth check out this link it may help ya out
https://www.thirdgen.org/techbb2/sea...der=descending
also PM Bort62 he may be able to burn a custom chip for you.
Old Dec 7, 2002 | 11:52 AM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Well, you will find that a lot of the guys with some decent info on this board will "require" that you read first before posting. It is how it is and it has been like that ever since i got here, even before i started to post. So, just do a search next time. Thats all. I am sure if you punched in "chip" you will find more info than you would know what to do with! About the aftermarket chips to buy, don't even bother with Hyperjunk or Jet, they are junk. People have tested them on here and there is not that much of a difference between those chips and the one siting in your car! If you would like to buy a chip, go to www.fastchip.com, they are pretty reputable and they will work with you! I wouldn't invest in one unless you have some decent mods. Sounds like your car is stock. If thats the case, just do a bit of reading on here and you can get into prom burning yourself. I believe there was a guy on here with a stock 305 tpi who got his stock car into the 14s with just tuning his own proms/chip. Hope this helps! Oh, and being a di ck back will not only give you a "bad name" in some people's eyes, it will also cause those two people to not help you out again! Seriously, let people be whatever they want to be, just let it go. Finding help is a pain when you do not get the answer you are looking for but what you did is not going to make it any better IMO. You will find out shortly that there are many different personalities on here, so just live with it and ignore the *** holes! good luck
Jorlain
Oct 8, 2015 01:57 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
