Idle problem sometimes
Old Dec 13, 2002 | 01:50 AM
JohnS's Avatar
Car: 2004 Nissan 350Z
Engine: 3.5 V6
Transmission: 5 speed auto
it doesn't do it constantly,but i come to a stop light and it idles at 1000rpms then i tap the gas just a little and it goes back to the normal 500rpms and stays there.What is causing this to happen?Thanks
Old Dec 13, 2002 | 08:45 AM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
There are a few things to check that effect Idle quality.
The Idle Air Motor, on the bottom if the TB. That could be dirty, of no good, try cleaning it with come carb cleaner 1st.
TPS sensor on the Pass. side of the TB above the IAC, could need adjusted or replaced.
Vacuum leak, a tube could be off, bad gasket
Worst case scenario, ECM at which i cant help you with, I havent dug into that part of the car yet.
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
