Could you guys give me som feedback on my plans..
Old Dec 19, 2002 | 01:32 PM
devilfish's Avatar
Hello
COuld you give me som feedback on this please?
Im on a tight budget,so keep that in mind. And Im from Sweden so many thins is hard to get "over here".
And its for my 1991 6spd vette.
here is the list:
LPE219 cam
LT4 springs, reatiners etc. ( im not going abow 6000rpm, so it should be enough)
accel superram bas ( ony base )
as+m runners.
ported stock plenum, to match the as+m runners.
Stock TB.
Going to cheap port the 113 heads myself, match it to the accel base.
manley vavles ( stock size )
Increase the comp using a diffrent head gasaget then stock.
heddman headers.
1,5rr, i dont think the stock heads can flow abow .500 in lift, so i stick to 1,5.
no egr
no airpump.
And to add in the future..
superram plenum and runners
hooker headers
AFR heads
1,6 rr
stronger springs
bigger vavles
Does this sound like a good "cheap" top end for now?
Is 370hp possibel with good tuning?
devil....
Old Dec 19, 2002 | 06:45 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
That sounds like a good build to me - 370HP to the wheels without suspension/transmission mods not possible IMO.
Old Dec 19, 2002 | 08:53 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
I agree. Maybe 320-330HP at the crank at the most
Old Dec 20, 2002 | 10:01 AM
devilfish's Avatar
thanks for the reply.
I know that a simular set-up made 322 hk at the wheels.
His car whas a 1988corvette 4+3manual.
His setup whas just like mine but with the following diffrences.
superram upper and under.
fully ported 113 heads.
2.02 vavles
1,6rrs
hooker headers.
so that should be around 380 hp at the crank.
Im happy if i can make 350hp at the crank with this setup.
I have a hard time to belive that the superram upper, 1,6rrs, bigger vavles should make 50 hp more then my setup, 30hp i can buy..or?
What suspension/transmission mods could help me? I got a 6spd manuall tranny, how should I mod that?? Im confused..
regards
Old Dec 23, 2002 | 03:56 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Mmmm...
Subframe connectors - will improve weight transfer off the line and stiffen up the whole frame for better handling, noise etc.
Strut tower braces - In the front and back will allow you to corner like a bad word.
Both relatively cheap and both help alot to ease the inherent weaknesses of the unibody frame.
Old Dec 24, 2002 | 08:07 PM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
Devil nice to see you over here. I still think you'll be able to squeeze at least a good 370 (at the crank) outta her with the whole list of stuff.
Old Dec 24, 2002 | 10:54 PM
xanax's Avatar
370hp with long runners isnt going to happen without more cubes. maybe after the super ram upper. ignore the suspension mods listed for you if your doing this to your vette. youve got a pretty good stock setup on a vette for a good hookup. on the tranny, just make sure your clutch is in good shape and your good to go.
Old Dec 24, 2002 | 11:41 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
vettes have a full frame
Old Dec 25, 2002 | 02:17 PM
devilfish's Avatar
Yepp im everywhere So whats happening with your car ?
Old Dec 25, 2002 | 02:19 PM
scorp508's Avatar
Car: Corvettes
I'm waiting for the cylinder head to come back from the welder.
Old Dec 25, 2002 | 04:18 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Whoops! I forgot to notice that he did say it was a Corvette and not an F-Body
jhawkeye
May 25, 2022 06:33 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Street Lethal
Aug 14, 2015 08:25 PM
