MSD Bkaster Coil
Old Dec 19, 2002 | 08:39 PM
DrekkenX's Avatar
MSD Bkaster Coil
Right so I got my ole' 88 Roc 350 TPI. A freely aquired an MSD Blaster coil and threw it in. It being of a higher step up voltage, should I regap my plugs? Get a bigger spark? Is the coil good for anything? I also got a 6AL for free, but that looked a little bit more time consuming than 5min, so I left that to the side Thanks! - Tom
p.s. Happy Holidays!!
Old Dec 20, 2002 | 03:00 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Install the 6AL! Free? You just saved like 120 bucks =9
Since you got a coil for free, and a box for free, you should buy some 8mm spiro-type wires and slap on an msd cap&rotor and youd have yourself a great ignition for a street car.
Plus - all MSD stuff (pretty cool - im into consistency)
Old Dec 22, 2002 | 08:38 PM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
I highly recommend you get the low resistance MSD HEI bushing.
MSD Part #: 8412
Summit Part #: MSD-8412
http://store.summitracing.com/partdetail.asp?part=9047
It costs $11.50 and will allow more of your newly found voltage to pass through. The stock bushing is a high resistance unit and causes large amounts of heat to build up under the coil which will kill it earlier than it should. Cheap insurance.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
meeklay812
Oct 1, 2015 03:46 PM
