TPIS minram, holley stealth ram, or accel superram
Old Dec 6, 2002 | 10:27 AM
StylnCamaro's Avatar
I was thinking about building my motor to a 383 400hp plus tpi. I'm looking for a new induction system and currently am looking at the accel superram with accels manifold b/c I think that is the only manifold that will fit that. But was looking at the mini ram in the TPIS magazine I have and says it could put out 95+hp on ported or worked engines. Also the stealth ram I don't know anything about it btu I'm doing some research here and there about it. Which systems do you guys like out there? Even if it is something different then what I named your reponces would be great. Also post some pics if you have
Old Dec 6, 2002 | 10:37 AM
86 IROC's Avatar
All (3) manifolds will help you achieve your 400 HP goal. I like the Stealth Ram & LT1 conversion because of the price - I have a Mini Ram on my personal 383. The Super Ram is the only emissions legal one out of the group, if you require emissions... the SR gets the vote.
Old Dec 6, 2002 | 05:05 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
I like the superram b/c of the emissions factor - however all of them are adequate.
Think about low end torque tho, the SR will maintain the low end torque better than the others, while still giving substantially higher revs.
Old Dec 7, 2002 | 07:39 AM
e-man's Avatar
Car: 89 formula
Engine: 383
Get the Stealth Ram its the best for the money.I can break the tire's loose at 15mph if I punch it with my set up.So there is no need for any more torque down low(super ram) and it will pull to over 6000rpm with out a problem(mini ram).Or if you want to be different here is a couple of single planes converted for EFI The first is a Edelbrock's new Victor EFI the second is Holleys Weiand Stealth
Old Dec 7, 2002 | 02:50 PM
would these prices sound right, well avarage prices anyways
Super ram with intake about 1100
mini ram about 1200
and the stealth about 2000
Old Dec 7, 2002 | 10:08 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Stealthram about 700 bud, cause you need the new rails.
THe stealthram cannot be beat as far as price goes, expcept maaaaybeeee by the LT1.
Hey I thought those single planes were for carbs! =(
How in the world do our runners hook up? Or would you need other stuff for the weiand and edelbrock single planes?
Please explain, I now am interested =9
Old Dec 8, 2002 | 09:18 AM
e-man's Avatar
Car: 89 formula
Engine: 383
I paid around $500 for my stealth ram W/rails. Heres the T-body and complete pic.
Old Dec 8, 2002 | 02:32 PM
hey e-man isn't that for carb or is that what it looks like without the plenum on it?
Old Dec 8, 2002 | 02:50 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
There IS no plenum........right guys?
Old Dec 8, 2002 | 04:24 PM
Bort62's Avatar
Single plane EFI like the one pictured Above is very similar to Carb or TBI As far as the Intake Design. There is no plenum persay, But in reality there is plenum Volume under the throttle body.
The differance in Single plane multiport EFI vrs a Carb, or TBI is that the Throttle body is dry flow - No fuel.
The Fuel is injected at the intake port the same as our TPI systems.
So the dynamics of intake design and fucntion are quite similar to a carb setup, While the fuel delivery has all the benifits of port injection.
Really a great setup for the full Boogie Motor.
Old Dec 8, 2002 | 08:39 PM
so that intake would take the place of the tpi? And what I mean by stealth ram is the one in this link
holley stealth ram
Old Dec 9, 2002 | 04:38 AM
e-man's Avatar
Car: 89 formula
Engine: 383
Styln,Yes that single plane takes the place of the TPI.That is the stealth ram but you dont need those $1700-$2300 kits if you allready have TPI you just need the manifold and fuel rails less than $500.
Old Dec 9, 2002 | 12:45 PM
LETHALRACER's Avatar
The Super Ram sucks for instal and maintenance. I am pretty sure the Super Ram wins the torque debate. The Miniram ownes the top end with almost no limit. The Stealth Ram seems to fill the gap between the two. I have personaly owned the Super and the Mini. On my AFR 210 heads the Mini only absorbed 10cfm up to .700 lift. The Super on the other hand absorbed 50+cfm. This was on heads that flowed 298.6 @ .600. The Super was done by 5,800rpm and I rev my Mini to 6,700 with a slight restriction. I can feel the torque difference, but I have a 4,000 stall so there is no need for torque down low. I blow the tires off at any thing less than 40mph. The Super is notorious for vacumm leaks. The gasket kit is $24 and will take you a couple of hours to take apart. The Super never ligns up and usually need some masaging to work properly. I would stay away from the Super and go with the Stealth if you are not looking for the limits of your combo. The Stealth seems to be putting out some realy good numbers up to 6,500rpm. Go Mini if you want ungodly top end.
Old Dec 9, 2002 | 08:43 PM
Shagwell's Avatar
Car: projects.......
I've heard a lot of good about the Stealthram. I'm going to be installing it myself in a few months, so I'll know more then. If you already have a TPI, then, as stated, it will only run you about $500. It is deffinitely the best for the more middle of the road car. That is, not a Camry, and not John Force. -
Old Dec 10, 2002 | 05:59 AM
F0xBody50's Avatar
Stock TPI Throttle Body, Plenum and Runners will work with SR?
Seems like it'd be restrictive... and will the custom fuel rails fit with the stock TPI equipment?
Sorry if I'm wrong, but it seems like those kits are necessary...
Where can you go about ordering just the manifold + fuel rails?
-LJ
Old Dec 10, 2002 | 04:26 PM
e-man's Avatar
Car: 89 formula
Engine: 383
ONE2FLY You reuse the T-body,injectors,and sensors thats it.You need some adapters for the fuel line do a search on the stealth ram you will find all the info you need for the swap.Heres pics of the bare manifold
Old Dec 10, 2002 | 08:42 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
e-man:
Are both of those pics you posted of the Stealth Ram? The first one looks like a FI 4-barrel and these last two look like a modified TPI. Which one is which?
Old Dec 11, 2002 | 01:28 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
The 2 last pics are the stealthram.......
Old Dec 11, 2002 | 01:53 AM
89transam's Avatar
here let me save you some trouble
http://www.thunderracing.com/index.c...ategoryid=1125
Old Dec 11, 2002 | 09:36 AM
Brian'sIROC's Avatar
I wish someone would come out with an emissions legal manifold other than the super ram.
Old Dec 11, 2002 | 01:55 PM
Brad's Avatar
For approximately $450, you get everything you see here, except the pretty red powder coating
Old Dec 11, 2002 | 05:45 PM
Thanks for the link 89transam. Brad is this what you have on your car? and do you have anytimes for the 396, how bout a picture of the car and motor too.Nevermind I just seen your link now
Old Dec 22, 2002 | 11:44 AM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
Brad
Brad where can you get that for $450 I thought that setup runs about $800? Let me know i'd jump on that for $450. thanks.
Old Dec 22, 2002 | 07:41 PM
89transam's Avatar
I posted the link look up
Old Dec 22, 2002 | 10:04 PM
Gruvin84SS's Avatar
How much trouble would it be to build a plenum to set on that manifold. I know they make the elbow things but I dont like them very well. Wondering more about a stock TPI looking plenum(except that it stops breifly after covering the hole in the middle, leaving plenty of room for the distributor)
9192camaro
16
Feb 3, 2019 12:21 AM
tazs2000
Jul 15, 2017 08:44 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Sanjay
Aug 12, 2015 03:41 PM
L98GTA87
Aug 11, 2015 06:55 PM
