Which cams have enough overlap so that the EGR is redundant and is not needed?
Old Dec 22, 2002 | 12:13 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
Looking for information on which cams have enough overlap in valve timing so that the EGR valve becomes redundant and is not needed. Such as the '96 LT4 motors in the Vette which did not need an EGR valve to pass strict emmissions tests.
And will work very well in a TPI motor of course...
Old Dec 22, 2002 | 03:11 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
Not saying your wrong, but I have never heard of such a thing and I am basically aiding you in a TTT cause I wanna know the answer to this as well. Not only which cam would have enough of this overlap you speak of, but also, how and why this works.
Old Dec 22, 2002 | 04:53 PM
2QUIK6's Avatar
Yes, this is possible as all LT4 motors do not have an EGR valve. This is possible because the exhaust valve is not completely closed when the intake opens and the piston begins traveling downward, sucking in both fresh air/fuel mixture and the spent exhaust gases from the slightly open exhaust valve.
This creates an internal EGR like valve, so the EGR is redundant and is eliminated in the LT4 motors.
Here's a few links detailing the difference in the LT1 and LT4, EGR eliminated is one mentioned.
http://www.malcams.com/legacy/misc/LT4.htm
And look down at #6 on this page:
http://www.geocities.com/MotorCity/S...5/camaro1.html
So, anybody know what the min/max lope separation is so that the EGR can be eliminated and still pass emissions?
Would like to use Vortec heads and don't want to have to weld on my headers and make an external EGR.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
drathaar907
Aug 6, 2015 04:20 PM
