comp XE276
Old Dec 29, 2002 | 08:03 AM
scottydta's Avatar
Car: 1989 Trans Am
Transmission: 700R-4
comp XE276
wanted to get some feedback from others that are running this cam on their 350's. need to know if it is compatible with the stock chip. stock chip meaning a hypertech upgrade if ya want to call it that. i have all other updrades to support the cam but don't want to fight tuning issues if the stock chip is gonna be the deciding factor. if it's to much cam any suggestions? running a slp cold air kit, fully ported TB and plenum, edelbrock runners and baseplate, pocket ported L98 heads,1.5 rollers, edelbrock TES, flowmaster 3 in. catback, TCI 2400 stall, accel ignition.
Old Dec 30, 2002 | 02:38 AM
Odyssey's Avatar
Any cam will "work" with the stock chip and be "compatible" with it. It's all a matter of how much you want to wait until you can burn a custom chip to match that cam. The 276 is small enough that you dont have to worry abou that for a long while.
Old Dec 30, 2002 | 11:40 AM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
What year is your car? A SD system will not like the lower vacume at all and probably won't run very well at all, a MAF system would run better but still would not like that big of a cam. If your SD I wouldn't run it at all, if your MAF you would be able to get by i think... I'm running the xe 270hr and although it runs rich at startup it still runs good.
Pac J
May 17, 2020 10:44 AM
no green
Jan 9, 2016 09:22 PM
