Pagin 85MikeTPI
Old Jan 1, 2003 | 11:50 AM
devilfish's Avatar
Pagin 85MikeTPI
Did you have anny tuning problemes with the lt4hotcam and the HSR? Or whas it ok to tune?
and
IS the Holley Stealth ram with holley fuelrail ( if you dont count in the hood issue for the corvette) a direct bolt on setup? Both base and plenum? Is all the vaccume / coolings stuff there?
Or do you need to tweak the HSR to make it fit a L98 block?
regards
-=corvette 1991 6spd =-
Old Jan 1, 2003 | 02:56 PM
kevinc's Avatar
Car: 1982 Z28
I'm running that very setup, HSR with HOT cam. Nothing special about software tuning, it responds to VE and PE table changes very predictably.
You have to buy vacuum fittings, but the threaded holes are there. The sticky post on the HSR covers what you need.
robguitargod1
Dec 13, 2011 08:45 PM
