Nasty Oil Leak...HELP!!!!
Old Jan 1, 2003 | 07:38 PM
Vicious 88 GTA's Avatar
I have this nasty oil leak coming from my engine and it is leaking onto the Y Pipe and burning it every time a drop falls...it also leaves like four big puddles under the car like this
right under the oil pan and I don't know what it could be....it seems like it is coming from the back of the engine....AARON
Old Jan 1, 2003 | 07:49 PM
4L60bliss's Avatar
Could be alot of things. The oil pressure sending unit could be leaking, the back of the intake manifold could be leaking, the distributer gasket could be leaking, rear main seal could be leaking, etc...
You'll probably have to dig a little deeper to find out what it could be.
Old Jan 1, 2003 | 07:54 PM
where is the oil pressure sending unit located
I have noticed my oil pressure guage goes crazy and always drops the pressure and when I jam on the gas it starts to leak more oil....I have wondered about that...where is the oil pressure sendind unit located????...AARON
Old Jan 1, 2003 | 09:30 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
It should be a long cylinder looking device above the oil filter. Does your gauge show no oil pressure at idle?
When my sender was leaking i showed no oil pressure at idle, but yet my engine made no noise or siezed!
Old Jan 1, 2003 | 09:55 PM
4L60bliss's Avatar
Well, depending on the year will determine where the sending unit is. On a '92, it will be above the oil filter. On the '88, it still should be behind the intake manifold. There should be two on the '88. A very small two-wire sensor for the fuel pump and a very large one-wire which is the sending unit. I know when my sending unit went bad, the gauge went crazy and spewed oil everywhere. Since you mention the guage, it sounds like that is the culprit.
Old Jan 1, 2003 | 11:45 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
Will be a short fat assembly screwed into a small boss directly behind the distributor. Looks very much like the temp sensors in the sides of the heads. Also check valve cover gaskets.
Old Jan 3, 2003 | 03:00 AM
you know...
today while installing my 8.8 Accel Spiral core wires...i noticed a little chubby tube by the drivers side manifold with a wire connected not leaking any thing...but on the pass side at the back top of the valve cover there was alot of oil...then when I turned my car on...the drivers side by the valve cover threw a puff of smoke....weird huh...AARON..please help
Old Jan 3, 2003 | 11:45 PM
72LT1VETTE's Avatar
Engine: 350 HO
Axle/Gears: 336
Check for a clogged vent tube on the passenger side valve cover and check for a clogged PCV valve. Internal engine pressure may be building and pushing the oil out due to one these being clogged not allowing the engine to breathe.
jrdturbo
Mar 31, 2016 02:58 PM
bigjay89gta
Oct 15, 2015 08:04 AM
skinny z
Oct 5, 2015 06:23 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
