New Fuel Pump
Old Jan 4, 2003 | 08:29 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
New Fuel Pump
Didn't really know where to post this so... Is there a fuel pump that can handle a S/C application while still running efficiently on an N/A motor. What i am saying is, can i get a pump now that will basically last me, if i decide to put on a S/C down the road? Or will i have to get a different pump when i get the S/C. I would like to swap out my pump now when i get a new rear and it would just be easier to leave it in there for the years to come, instead of switching down the road again! If not, then i can deal with that too. Also, which pumps would you recommend? Walbro, or maybe Aeromotive? Tried a search but really didn't get a good answer for my specific question. Maybe i should try the power adder board too? Thanks for your time.
Old Jan 5, 2003 | 01:13 PM
MdFormula350's Avatar
https://www.thirdgen.org/techbb2/sho...el+pump+walbro
i ran a search seems like walbro makes good high flow pumps..
Old Jan 5, 2003 | 05:40 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Thanks, there is also this really good thread on those pumps that i came across too. I guess what i want to know is, Is there too large of a pump for an N/A motor? I mean, i need a pump to work for an N/A set up as well as a super charged set up. I guess i'll call some companies tommorrow and see what they recommend. Anyone else recommend any pumps to get? Thanks
Old Jan 6, 2003 | 08:31 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Anyone using the Walbro 60+ psi pump from Racetronix? It is a "plug and play" deal with everything included to make it work. Its around $170, $180. Are there other pumps i should look at too? Like Aeromotive or Holley. I was out today and did not get home to call anyone during business hours so no new info really! So, what do you recommend? Thanks for your time.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
