sticky throttle
Old Jan 10, 2003 | 01:07 AM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
sticky throttle
hey guys,
i replaced my throttle body on my 1988 GTA with 305/5.0L TPI in 2001. it was a stock 52mm throttle body. ever since i had the shop put it in it has been sticking in the closed position every so often and i have to tap my foot on the gas pedal to unstick it. sometimes it's harder to unstick then other times. it's not one of those fancy BBk or edelbrock ones, it's the stock TB from GM. i've had it inspected and cleaned numerous times and still nothing. has anything like this happened to you guys? if so, what did you do?
as always, all who contribute important info on curing my problem will be treated like GODS :hail:
Mark, NJ
P.S. i told my brother (from whom i bought the car from) that it was doing this and that i wanted to get another one and he said i should wait and see if it "wears in". needless to say, it didn't
Old Jan 10, 2003 | 01:13 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
the shaft the blades are on wears out the bushings at the ends. I believe you can just rebush the TB. The fact that it's been doing this from the get-go means you need to repair it or install a decent one that isn't worn.
I think stock TB is 48mm, too.
Old Jan 10, 2003 | 01:47 AM
GTAman's Avatar
thanks alot for the info and the correction, jmd :hail:
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
Z28/ZR1
Oct 23, 2015 01:04 PM
HoosierinWA
Oct 7, 2015 10:15 AM
dusterbd
Sep 29, 2015 08:40 AM
