car is acting up so much, i got pulled over
Old Jan 9, 2003 | 03:29 PM
bigals87z28's Avatar
Car: Check The Sig
Oh boy, where do I begin....
Ok.. #1. at idle.. the car shimmies a little.. i dunno.. it goes smooth.. then a little ruff vibration.. then smooth...
#2. today i was driving, and when i am driving arond 40-50, it feels as if something is blocking the exhaust.. but then it will clear up, and then go blocked again. #3. funny fuel smell and large amount of fuel consumtion... i saw a post on this already, i just thought i could add it in to see if any of the posted problems are related... whatever i have in my car is in my sig... i am puttin in msd 8.5 mm wires in today... im gunna check for vacum leaks right now.. please help me fellas thanks
Old Jan 9, 2003 | 11:11 PM
Car: Check The Sig
well fellas!!! also, im doing my plug wires now... and it looks like mr. haynes manual isnt agreeing on how the wires are set... they show a different wire set up then what is on the car now... someone please help me
Old Jan 9, 2003 | 11:15 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
different setup? I just loom my wires together and drape them over the valve covers, making damn sure they don't rub on the exhaust. I never use the factory 'behind the engine' ones. Are your wires pre-made or custom fit?
Old Jan 9, 2003 | 11:20 PM
Car: Check The Sig
wires are pre made.. but not on how they fit...haynes manual has a pic of the cylenders and then a pic of the dist. and its showing the numbers corisoponding to each cylinder... and its not how it is on my car... for example.. in haynes it says #2 is across from cycl 1.. but on the cap teh placement of 1 and 2 are different then whats on my car...
Old Jan 9, 2003 | 11:45 PM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
clogged Cat? could have chunks in there, that block, and then move and unblock and back and forth.
Could cause fuel smell, and would definetally effect mileage.
Old Jan 10, 2003 | 12:13 AM
Car: Check The Sig
ahh i really need help with the wires.. im puttin them back on the way they were, since the car ran at at that point... could the HEI with the coil in cap have a different set up then mine with an external coil?
Old Jan 10, 2003 | 01:11 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
No, firing order is the same. Clockwise, they must be 18346572.
Old Jan 10, 2003 | 05:50 AM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
18436572 - I'm sure that was a typo
Ghettobird52
Jul 5, 2024 11:18 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
