What about Portin the TB openings on the plenuM?
Old Jan 11, 2003 | 09:25 PM
Larry Dunlap's Avatar
Car: '91 Formula
Transmission: TH350 built
OK, this is probably a stupid question, BUT, If you put a 52mm or 58mm TB on a TPI 350, I guess youve got to port the two openings in the plenum that match up to the TB openings to get any advantage right? What about the bevel that is on these openings? The diameter towards the interior of the plenum is slightly smaller than the diamter that matches up to the TB. Any reason for this, or bette to just port that to the same size as the TB as well?
Old Jan 11, 2003 | 09:27 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
I'd smooth it off a bit, but I would not open it up any larger than the throttle body bores. One of those "while you have it off the engine... mightaswells"
Old Jan 11, 2003 | 09:29 PM
Car: '91 Formula
Right, exactly, thats what I thought. Just make the opening the same size as the TB bores and get rid of that bevel.
Old Jan 12, 2003 | 08:05 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
The holes are already 52mm so you're OK unless you get a 50mm TB.
You would then port the holes to at least that same size (58mm) of the TB. It's OK if you make the holes bigger, just as long as their at least the size of the TB opening. You want to avoid having a step there to interfer with the incoming air.
Old Jan 14, 2003 | 06:27 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Yes, port the plenum holes for a 52mm or 58mm TB. Also, there are some bumps of metal sticking up into the airstream inside the plenum, cut these down also.
Old Jan 14, 2003 | 07:55 PM
Guest
Guest
Posts: n/a
About the best you can do with a 58 is match it at the face of the plenum, and taper it in from there. The plenum isnt wide enough to enlarge it for a 58 without a fairly sharp taper into the plenum, you have to weld it if you want to transition it better.
Old Jan 14, 2003 | 08:33 PM
Car: '91 Formula
Yeah I already removed the egr walls and did some other minor smoothing a while back, I was specifically asking about the tb holes on the front and the taper that is there on a stock one. I just basically removed the taper although there still is a little, and opened up the holes about 2mm on all sides to accomodate the 52mm. Just wondered about that taper tho
Old Jan 14, 2003 | 09:26 PM
Guest
Guest
Posts: n/a
Totally useless.
Old Jan 14, 2003 | 10:27 PM
Car: '91 Formula
the taper is "totally useless" or porting of the the plenum in general?
Old Jan 15, 2003 | 12:37 AM
Guest
Guest
Posts: n/a
Both. LOL!
Nah, I cant see any reason for the taper. Its bigger than the back of the stock TB. Probably has something to do with the machining process I would guess.
Old Jan 15, 2003 | 07:53 AM
Car: '91 Formula
haha, you are probably right on both accounts, but it gives us poor people who cant afford a Lingenfelter Supperram setup something to do eh?
Pac J
May 17, 2020 10:44 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
Nick McCardle
Sep 10, 2015 08:36 PM
