30# injectors?
30# injectors?
one of my mechanics says i should go with these for what i plan to do....
what is a good rule to understand how high a number needed for a setup. is there anywhere to go to learn more about injectors?
Car: 86 Iroc-Z28
Engine: FB385
From your other post, i am guessing you are getting your heads port and polished too, or just the intake? TPIS should have been able to recommend the size of the injectors for you. Depending on what cam you are going with also matters. If it helps, i am using the Ford 24lb/hr injectors on my set up. Everyone i have spoken to or asked said i should be fine and my chip is tuned for them already ,so we'll see. Sorry, don't really know where to find generic injector info or a type of calculating system, if there is one. good luck
check here http://www.bgsoflex.com/pwcomp.html
thejimsterz28
Sep 15, 2015 04:37 PM
