the best cam for stock TPI and on..
Subscribe
Jan 15, 2003 | 04:22 AM
If you would put in a cam for the stock tpi and later add the superram. What would that be? If you dont whant the hassel to swap cam again.
Reply 0
Jan 15, 2003 | 04:34 AM
ME personally, I'd go with the ZZ4 cam. Alot of people are going to tell you it's too small, but if the car sees any daily driving, it's a great cam. Fact is, it will help the TPI make even more torque than it does now, and IMHO, when you add the SuperRam, or anything else that can help the TPI pick up power higher in RPM range, it will still make good HP numbers.
Plus I'm cheap, and you can pick up the ZZ4 cam for around $100.
HTH
Reply 0
Jan 15, 2003 | 04:37 AM
what about the lt4 hot cam?
Reply 0
Subscribe
