Removed Fac. Oil Cooler, How do I mount Filter to block?
Old Jan 21, 2003 | 10:42 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I got the 2 steel tubes gone and I need to remove the sandwich piece now. what exactly do I do and what do I need to atach filter to the block. Thanks I've looked in the search but just found rough answers
Old Jan 22, 2003 | 11:40 AM
jmon92conv's Avatar
you need the piece that bolts to the block to accept the filter. Try going to a machine shop, they probably have these sitting around. THe bolts are shorter also so get those
Jeremy
Old Jan 22, 2003 | 11:47 AM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
i would just like to know why you took it of
Old Jan 22, 2003 | 11:51 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
They were getting in the way of my Long Tubes and also the lines were starting to rust out, and also with my old headers the heat from them would make the rubber hose right by the cooler harden and crack causing leaks.
Old Jan 22, 2003 | 11:57 AM
Guest
Guest
Posts: n/a
Its been a while, but it seems to me you just need to remove the old bolts and replace them with new ones that dont stick out so far. IIRC, the adapter is already there.
Old Jan 26, 2003 | 01:38 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Anyone have an oil temp gauge on non cooled oil? Im just curious.
maroe624
Apr 16, 2017 08:29 AM
Navy8125
Aug 21, 2015 09:32 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
3rdgenparts
Aug 8, 2015 07:09 PM
