fuel pump ques
Old Jan 22, 2003 | 11:35 AM
jmon92conv's Avatar
fuel pump ques
when I turn the car off, the pump continues to run for like 5-10 sec. I have not noticed it running this long before. Is it the pump going south or the relay or what? Any ideas?
Jeremy
Old Jan 22, 2003 | 12:00 PM
90form305tpi's Avatar
Car: 1990 Firebird Formula 305
Engine: 305tpi w/145,000 on the clock
My car has been doing the same thing for about two months now. I read in a thread in the archives that suggest it's do to a bad oil pressure switch. The switch cuts off the feul pump if the oil pressure drops below a certain amount. I replaced mine and it still does it. Any other suggestions would be greatly appreciated. I plan on replacing the feul pump in two weeks. I'll post the results if it hasn't been figured out by then.
Old Jan 22, 2003 | 12:15 PM
Morley's Avatar
Sticky relay. If the pump were bad it wouldn't make it run on, when you turn the key off the power holding the relay is cut and there by cuts power to the pump. But if the relay sticks it will continue to supply power to the pump.
Old Jan 22, 2003 | 02:30 PM
jmon92conv's Avatar
kind of what I thought. I will replace it today.
Jeremy
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
