need to go slow
Old Jan 23, 2003 | 12:51 PM
no money's Avatar
need to go slow
I was told that i need to loan my brother in law my car bad deal. So here's what i want to do is burn a valet chip any ideas on what i need to change to make it go slow burn lots of gas. As you can tell i'am not happy about this. My first thought was retard timing after that i don't know.
Old Jan 23, 2003 | 01:53 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: need to go slow
Burn a new chip with these changes: reduce engine speed limiter and MPH limter. In the main SA & high spd SA tables reduce the timing as the engine RPM increases from 65 KPA to 100KPA areas.
Set the PE TPS% levels to 100% across the board.
Test drive it so that the performance (or lack thereof) is to your liking. Don't reduce the MPH limiter too low as it could cause a stalling problem.
RBob.
Old Jan 23, 2003 | 02:20 PM
Morley's Avatar
Re: need to go slow
Unless I wrecked my brother-in-law's car I'd tell him that as long as he has shoes he has transportation.
Old Jan 23, 2003 | 02:35 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
Whare are you worried about your brother in law destroying your car? Is he that bad of a driver? Big accident record?
It just seems unusual to me. I'd let him use the car with the express knowledge that if he screwed it up he'd be paying to fix it. Unless he's a completely irresponsible dimwit.
Old Jan 23, 2003 | 03:54 PM
no money's Avatar
Thanks for info and yes he is a broke out of work lazy dimwit got to go look for work but he's not going fast in my ride if i can help it. Sort of a truning challange you know want he be suprised when floors it.
RedLeader289
May 28, 2019 01:47 PM
Elephantismo
Feb 13, 2019 12:51 AM
Ed1LE
Sep 30, 2018 09:14 AM
bjpotter
Oct 4, 2015 07:48 PM
Luigytico09
Oct 1, 2015 08:46 AM
