Miniram fuel lines
Old Jan 23, 2003 | 08:11 PM
STIFFLER's Avatar
Miniram fuel lines
Anyone have the part numbers for the fittings I need for a miniram and how long of braided hose etc... and where I can get it from?
Old Jan 24, 2003 | 07:40 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Take a guess ... I don't remember the exact PNs ....
Also look here to get an idea of length:
http://www.celligent.com/tim/iroc/progress/
Also look here for the fitting from the stock hardlines on the driver's side frame to the AN line:
http://www.holley.com/HiOctn/ProdLin...A/9894DBH.html
Tim
Old Jan 24, 2003 | 06:16 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
With the help of those photos of Tim's set up i was able to put together pretty much the same thing. Although i used a 6ft line and cut it right in half to 3ft for each line. A little close, but works as long as you do not screw up on putting the fittings on! If i could do it over i would use an 8ft section. I then used a 180*,45*, 2 hose endings, all size No. 6, or -6 AN, whichever you call it. As for the fittings for the hard lines, still need to get those! TPIS gives you similar fittings as shown in Tim's Holley link, but they are silver and do not exactly thread right, so i'll just buy new ones. Oh yeah, i used all Russel fittings. Not too sure of the differences between the companies. Hope it helps as well but like Tim said, just check out the pictures. Thats what i did. I am learning as i go basically. I'll tell you, cutting the line was tuff for me. I don't know if it was because it was below freezing and i was just really easily aggrivated, but the lines really kicked my ***! You can get the parts through Summit/ Jeggs, wherever i guess. good luck
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
AkDrifted
Aug 17, 2015 07:45 PM
