I know this has been asked, but cant find it...
Old Jan 27, 2003 | 01:16 AM
bigals87z28's Avatar
Car: Check The Sig
How hard is it to swap a cam in to my 305? i wana go with a ZZ9 or some type of cam.. anythings better then my POS thats in there now... anyway... could i do it in my own garage?... what is needed, or should i just not even bother, and get it installed at a shop? i dont wana hear get a 350 bs... i am... its coming fellas.. but for now, i want a cam that will work good for the 305... i wana be gettin into the low 14's soon, and cam, full exhaust, and porting porting porting is what i think i need to get there.. im not gunna bother with heads... unless i can find a cheap pair of ported alum L98 heads...anyway.. give me some feed back on could i do this in my garage? or should i just go to a shop?
Old Jan 27, 2003 | 01:21 AM
rezinn's Avatar
Yeah you could do it in your garage. You just need a balancer puller/installer and a torque wrench. Gotta drain your cooling system, remove the intake manifold, lifters, radiator, condenser, water pump, timing cover and chain. You'll want to pick up intake gaskets and water pump gaskets, also some rtv and loctite and a timing chain/gears. A chiltons/helms/haynes manual would help, but you could do it without one by looking up torque specs and such.
Old Jan 27, 2003 | 07:37 AM
Car: Check The Sig
i got all the gaskets and RTV you could want... i got them on ebay.. nice set for like 35... ahhh i might just get someone install it
Old Jan 28, 2003 | 10:06 AM
Jza's Avatar
Jza
Try here. Buncha useful info.
https://www.thirdgen.org/techbb2/sea...der=descending
Old Jan 28, 2003 | 10:18 AM
Car: Check The Sig
thanks, but i did that already... and thats y i came here to find out some info... i thought there was some info, but i didnt see anything on what i need to put a new cam in..
Old Jan 28, 2003 | 04:14 PM
Jza's Avatar
Jza
Did you even try the link? Those were Sonar_un's old posts describing every single part, cost, and step involved in a basic cam swap. That wasn't just a general search on the word "cam swap". If you don't see what you need in there, then you aren't going to get anything better here at all. Check out Day 7.
Old Jan 28, 2003 | 04:21 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Dude just get a 350!!
I posted in IROC88x post called "valvetrain upgrades" about the parts that you'll need.
Good luck
Frozer!!!
Jan 19, 2024 04:55 PM
Mickeyruder
Sep 2, 2015 02:45 PM
89gtaforsale
Aug 24, 2015 09:32 PM
sreZ28
Aug 14, 2015 07:48 PM
