EGR blockoff
Old Feb 2, 2003 | 05:07 PM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
EGR blockoff
Anyone here every hear of blocking off your EGR valve?? Has anyone here done it??? If so, what are the benefits???
Old Feb 2, 2003 | 05:18 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
You can block it off, but make sure you disable the EGR in the PROM Chip for the ECM. Otherwise, you get a code 32, and it may have a small effect on performance/driveability, due to the fact that spark/fuel requirments will change when EGR is expected.
Old Feb 2, 2003 | 05:21 PM
speed88's Avatar
Engine: 383
How do you change it in the ECM??? What are the benefits ofblocking it off. I have heard that you will gain horsepower by dojng this mod, is this true??
Thanks for the reply.
Old Feb 2, 2003 | 05:30 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Probably won't gain any significant horsepower. The EGR isn't open during WOT, which is when you want most of your horepower anyhow. Most people block it off because they either set a code and don't want to replace it, or they just don't want to deal with it, not because they are looking for "more power". You have to go into the PROM using Prom Editing software such as "CATS engine tuner" and disable the diagnostics for EGR and change the EGR enable parameters so that it never gets turned on. But then you also need a way to erase your PROM and re-burn it. I use "The Pocket Programmer". Everything you need to know about PROM burning can be found in the "DIY PROM" forum.
Old Feb 2, 2003 | 06:21 PM
jonarotz's Avatar
Car: 91 Z28
In my opinion this mod isn't worth the hassle. I have done it on other vehicles and have not noticed much of an improvement, at least an improvement that can justify doing it. Just my opinion.
Old Feb 2, 2003 | 06:40 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
My point exactly. Like I said, its usually done by people who don't have provisions for EGR (aftermarket heads) or just don't want to deal with it.
Old Feb 2, 2003 | 10:11 PM
speed88's Avatar
Engine: 383
Thanks alot guys.
Old Jun 2, 2003 | 12:38 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Hate to bring this up but...
Im about to throw a TPI intake on my aftermarket heads and...
I dont have EGR ports in the heads, nor did the TPI intake come with an EGR valve and what not...
So what do i need to block off? I see the 2 holes in the top of the intake... is that it?
also im using Commander950 so i wont need to disable it, i just need to make sure there are no open holes in the intake to worry about. Anything else i may need to block off? I know about the CSinjector already.
Old Jun 2, 2003 | 01:23 AM
Z_Ghost's Avatar
Kingtal0n here is a pic for you, you just need to make or find the plate.
You could get some 1/8 aluminum and cut it with a jig saw then drill the 2 bolt holes, put a gasket on it and you are ready to go.
Old Jun 2, 2003 | 07:40 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
unless you cruise at freeway speeds with your car, you probably won't set a code without it. I haven't set one yet with my IROC, and I haven't had the motivation to upgrade my chip. The only time you'll usually see a problem is if you cruise at a constant speed for a long period of time.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
