a few TPI questions
Old Feb 2, 2003 | 06:55 PM
BikertrashDude's Avatar
a few TPI questions
Ok I have a few simple TPI questions.
1# is a aftermarket high flow MAF really worth it, $300 is alot of money
2# what is a MAF relay? I know where it is, I changed mine and it fixed the problem I was having but, what does it do?
3# differences in the 48mm throttle body (stock one right?) and 52mm and 58mm.
if I want to get a stealth ram in the future then can the 58mm I buy now (or should i get a 52mm?) for my TPI, fit on my stealth ram?
4# if I get a larger throttle body then do I need to change out my air filter assembly?
thanks
biker
...on probation
Old Feb 2, 2003 | 07:51 PM
Morley's Avatar
Re: a few TPI questions
All new MAF's cost about the same, unless I needed one I wouldn't replace the one I have.
The MAF uses 2 relays, one is for power to the MAF and the other is for the burn off function, this heats up the wire (on shut down) for a few ms to burn off any thing that may have stuck to it during operation.
The size of throttle body needed is dependant on the air requirements of your engine. Unless you plan on building 383 or a very potent 350, the stock TB will work just fine.
Nope, its all in the bore of the TB not the outward size of the unit.
Old Feb 2, 2003 | 08:06 PM
cool thanks
if I get a stealth ram can I use my stock TB?
engine is never getting stroked to 383.
mike graycar's Avatar
Car: 88 iroc x 2- 1 T-Top, 1 Vert
Engine: 350 tpi, 305 tpi
Transmission: 700R4-2800 stall, 700R4 stock
biker, you've been on here forever, how did you get on probation?
Old Feb 2, 2003 | 08:07 PM
No idea......never been on probation before. trying to fix it.
don't know who I pi$$ed off.
biker
...still on probation
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
