Quick Injector Question
Old Feb 2, 2003 | 11:30 PM
gtaguy87's Avatar
Car: 1998 Ram Air Trans am
Engine: Ls1
Transmission: 6 speed manual
Im looking to get some new injectors for my 87 GTA and i was wondering if there is any notice in performance increase. Im getting them because i plan on supercharging and it only requires 24lb but should i go with 30 for better flow will there be any difference. Also some reccomendations on some injectors thanks alot
Old Feb 3, 2003 | 12:37 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
You won't notice a performance increase with bigger injectors unless your motor needs it.
A set of 24lb Accel or Ford motorsport injectors should be OK but with a supercharger you could get away with running 30lbers.
Just make sure you burn a new chip for them!
Old Feb 3, 2003 | 08:01 PM
gtaguy87's Avatar
Engine: Ls1
I have an aftermarket chip but i dont know if it can handle 30lbs is there any way to know
Old Feb 3, 2003 | 08:15 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Unless you told the person that burned your chip that you are using 30lb injectors then it isn't set up for them.
Old Feb 3, 2003 | 10:32 PM
gtaguy87's Avatar
Engine: Ls1
so maybe i should just get 24lb ones that way i dont have to spend the extra cash for no performance increase, because if i get 24lb i dont have to change the chip correact?
Old Feb 4, 2003 | 01:36 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
You won't have to change it but your car would run better if you did. You should get a new one when you add your SC so maybe you can do it at the same time.
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
