Low Fuel Pressure
Old Feb 3, 2003 | 10:51 AM
SydwayzTA's Avatar
Car: 1986 Trans Am
Low Fuel Pressure
I am having some problems with my 1986 T/A 5.0L TPI. I checked my fuel psi and I am only getting 18-20, now i did check my engine check codes and it was reading a egr valve problem so i replaced that and so no more codes, but i was wondering if anyone had any ideas why my pressure is so low, it starts but only for a couple seconds really, then it just putters down and dies. I replaced the Dist Cap/Rotor Ignition coil, plugs, wires, new Edelbrock 52mm TB, ported plenum, and a new MAF, I was told a while back that it could be the fuel pump itself, but if anyone else has some ideas of somthing possibly causing this, any help would be greatly appreciated
Old Feb 3, 2003 | 12:19 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Fuel pump or possibly a clogged fuel filter.
Old Feb 3, 2003 | 12:27 PM
JohnnyIROC-Z's Avatar
Car: 1991 T-Top RS
Engine: 305 TBI
I'd replace the fuel filter (19.99 at autozone) and if that doesn't do it go for the fuel pump. Fuel filter is easy to replace. big metal cannister under the driver side of the car. Good luck!
Old Feb 4, 2003 | 02:04 AM
SydwayzTA's Avatar
Car: 1986 Trans Am
yeah i replaced the filter a while ago.... it seems obvious to me now that its the pump.. considering i changed the Fuel Pressure Reg, today and still 20psi......... Man i was not looking forward to droppin the tank, oh well, either way it wanted to come out, sending unit is bad too..... *sighs* anyone know if the pump and sendin unit are two differ pieces ? or both just one:lala:
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
