Car cranks but won't start
Old Feb 12, 2003 | 02:58 AM
jasman19's Avatar
Car: RED 1986 IROC-Z28
Engine: 350 5.7L
Transmission: TH 700R4
Axle/Gears: 3.23 10 Bolt
Here is the deal, I put on a mini ram intake and I got my car to run for a while. I noticed that the thing was leaking water on the passenger side toward the front. I soon realized that the miniram had been ported by the guy I bought it from and it was stuck on the flange of one of the valve covers. So I replaced the gasket again and made some grooves for the miniram to fit. Now my damn car won't start. I checked for spark and thats good. The only problem I can see is my fuel injectors aren't working. They are new accel 30 lbs injectors. I checked fuses and stuff, all good, checked fuel pressure, that is good too. I tried checking the wire lead to the fuel injectors but I don't know what the voltage should be. Anyone else had this problem? It's almost like the injectors are froze or something?? Thanks for any help
Old Feb 12, 2003 | 01:28 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
i had about the same thing happen to me a while back... mine would do the same thing but start sometimes and not others... it would crank but not fire... ended up it was the chip i had burnt for it was bad. you got the stock chip in there still? or is it an aftermarket one? or did you do it yourself?
Old Feb 12, 2003 | 03:21 PM
jasman19's Avatar
Engine: 350 5.7L
I still have the stock chip installed. The only thing that I have on the ECU itself is the ZIF connector. The car ran with the ZIF on it for a while. Today I checked the computer and everything seemed to be fine. I don't know how to check the fuel injector leads though, does anyone know how to do that? I went ahead and bought some new injectors from summit though. I figure if the new injectors don't work then the ECU is jacked and I can sell the injectors on ebay. Anyone else ever had this problem? Thanks for any help guys
Brcharrelson
Aug 26, 2015 07:47 PM
TheExaminer
Aug 26, 2015 04:59 PM
justin57
Aug 20, 2015 07:05 PM
mizz0313
Aug 12, 2015 06:45 AM
