LS1 injector upgrade
Old Feb 16, 2003 | 02:54 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
....I have a friend who is upgrading his LS1 with a turbo and he will not be needing his injectors. Do these injectors fit into a TPI system with no mods besides injector constant in the prom??? I was just curious if injector harness plugs, fuel rail clips, ect would all work with these injectors or is it a PITA to upgrade??? Also are there any reasons not to use these injectors on a TPI setup???? Thanks
Old Feb 16, 2003 | 05:48 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
The injectors will fit however the C clips won't fit around the LS1 injectors without grinding a groove in them. Those clips don't do much anyways because the injectors will stay in there on their own without them.
Old Feb 16, 2003 | 11:01 PM
Nasty_Bird_'90's Avatar
I second that. All will plug in just fine. Just like what was previously said, don't worry about grinding a groove in them fo the clip. The o- rings hold them in just fine.
Gimme some details on your buddy's project. I work on nothing but LS1's at the shop I'm at and like to see what other guys are up to
Old Feb 17, 2003 | 05:45 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
The car is a 1999 T/A. I know the company he is buying the turbo from is called ls1 speed. I don't know a whole lot more about it other than its damned expensive and I think its a twin turbo setup. He says it should have a good 500 hp and still be very streeable. Who knows, I guess we will see when he gets it all back together wether or not its a good idea. IMO he has too much money.
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
BAMiller
Sep 14, 2015 06:38 PM
zayne0
Aug 24, 2015 07:22 PM
