TPI Saw question (search isnt working)
Old Feb 17, 2003 | 12:01 PM
1989CamaroRs's Avatar
TPI Swap question (search isnt working)
I bought a tpi intake, plenum, and runners from ebay that Im sawpping into my 89rs. Year unknown but its for a 305 and it has the cold start injector. Im looking at ecms on ebay but I cant find one that the tpi article specifies. Will one from say a 1990 5.7 tpi vette work? Can I use any ecm that was used on tpi? What advantages do the 90-92 have over the 86-89? thanks normally I would have searched first cause Im sure theres plenty of posts about this but search wouldent work for me.
Old Feb 17, 2003 | 12:11 PM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
i think that would also bring up the issue of VATS is your car didn't come with it, not sure about that though. hopefully somebody can provide more information
Old Feb 17, 2003 | 01:08 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Check this out:
http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/
Did not read it but I bet is can answer some of your ?'s.
Old Feb 17, 2003 | 01:54 PM
Morley's Avatar
The ECM for it really depends on what year wiring harness you are using and how much pin swapping you can deal with.
If you plan on using the CSI, you need a 165 ECM with a MAF sensor. If you plan on disabling the CSI you can go with a 165 ECM and prom for 1989 (get VATS disabled) and still need the MAF. If otherwise you get the S/D harness for the TPI and the ECM and prom for it (again VATS disabled).
Vintageracer
Jan 10, 2020 05:33 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
squiggy2
Aug 9, 2015 09:30 PM
