[RW]HP-1/4 estimate with these mods?
Old Feb 18, 2003 | 11:03 PM
CETATornado's Avatar
What kind of horespower and torque numbers can I expect from an 89+ 305 TPI with the following mods? Any 1/4 mile estimates? Thanks in advance.
Hooker Catback
Dynomax Cat
Good set of headers - Edelbrock?
SLP (or similar) cold air intake/K&N
BFGoodrich g-Force T/A KDWS
New shocks/struts (Bilstein?)
Eibach Pro-Kit
Also, what results can I expect from a good set of heads and a moderate cam - i.e. 212-214 degrees duration at .050, less than .480 lift (combined with the above)?
Again, thanks for any help.
Old Feb 19, 2003 | 12:20 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Manual or Automatic?
Manual w/ decent driving and mods listed 14.8x assuming the car is in fresh tune and everything that should go without saying has been fixed/replaced.
Automatic w/ perfect launches and mods listed 15.2x.
Just taking a stab at it. I'm sure others will chime in soon enough.
Old Feb 19, 2003 | 07:39 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
That sounds about right. What gears do you have?
Old Feb 19, 2003 | 10:34 PM
It'd be a 5-speed, hence the 305.
I'm not sure of what gears I'd put on it, I haven't looked into that yet...
I'm taking it those numbers are without the H/C package?
Thanks.
Old Feb 20, 2003 | 01:02 AM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
You can run a 14.8ish or better dead stock with a late model dual cat 305 TPI 5spd car (3.4x gears, hotter cam stock)... A low low 14 or maybe even high 13 if you had a real good runner wouldn't suprise me at all with the pre-heads/cam mods assuming a good track and a decent launch...
Old Feb 20, 2003 | 07:36 PM
Thanks for the extra input Ray. That's exactly what I was thinking, 14.8 seemed rather low for those mods...my eventual goal is to get it as fast as the Trans Am - low 13's .
Quzyle
Oct 15, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
ULTM8Z
Sep 16, 2015 09:15 AM
