TPI off idle hesitation
Old Feb 19, 2003 | 12:44 PM
Tmony69's Avatar
Car: 89 IROC x2
What is the leading cause of off idle hesitation? It happens right when you stab the throttle. And for that matter, any cause.
Old Feb 19, 2003 | 01:05 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Four leading causes for an off idle stumble, I would say, are dirty/worn injectors, worn spark path (plugs, wires, distributor), vacuum leak, or a clogged or partially clogged fuel filter.
Old Feb 19, 2003 | 01:30 PM
Scrote's Avatar
I would also make sure that your TPS sensor sends a smooth voltage through out its range and that there is no dead spots...
But yeah, check to make sure you are getting good fuel pressure, and your high tension leads are in good condition, as well as your plugs...
Peace,
Erik
Wade787b
Sep 29, 2015 01:15 PM
db057
Aug 22, 2015 08:17 PM
Sanjay
Aug 12, 2015 03:41 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
