accel super ram
Old Feb 19, 2003 | 12:58 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
accel super ram
why is it that the super ram costs twice as much as holley stealth ram? what kinds of hp improvements could i get with the super ram on a 305tpi? anyone got pics of one installed?post em, thanks
Old Feb 19, 2003 | 01:36 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Concensus around here is that the Stealthram, Superram, LT1, and Miniram are all too much for the 305. I would suggest doing port work on your stock plenums. Siamese the runner entrances on both the upper and lower plenum, siamese the runner ends to match, and grind down the area right behind the throttle bore as well as radiusing the bores themselves for more air. Whether you do it or you get a shop to do it I think it would allow the 305 to breathe very nice. Thing is, the stealthram would bog the 305 big time in the low end, and I don't think the better top end will make up for it whens all is said and done. Unless of course you plan to heavily modify this 305, I would stick with long tube runner intake.
Old Feb 19, 2003 | 01:57 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
what about the edelbrock baseplate and runners with a ported plenum? i plan on lt4 cam, headers and new heads eventually
Old Feb 19, 2003 | 02:31 PM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
If you plan to do the mods listed, I think the base, runners and ported plenum would go nicely. Might tradeoff some torque.
Old Feb 19, 2003 | 04:02 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
I don't think the Edelbrock will trade off any noticeable amount of torque, and would be a really nice intake for the 305. I myself am getting one, I have the 350. I plan to keep it when the I stroke up to 383 cubes, but before it sits on top of a 383 I plan to pig the hell out of it to make it as good as it can be. Go for that, I think it'll compliment the cam you're putting in. Concentrate you're choice of heads around the 1500-5500 rpm range and you'll have a rather quick 305 TPI w/ decent breathing in the top end.
If you think you want to go with the edelbrock, you might look into siameseing the baseplate and runners for some more top end, in exchange for a smidge of low end torque.
Linson
Oct 24, 2025 02:00 PM
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
no green
Jan 9, 2016 09:22 PM
Dragonsys
Sep 25, 2015 03:51 PM
