Braided stailess fuel lines for LT1 intake
Old Feb 19, 2003 | 03:49 PM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
Well it's for an LT4 intake but the fuel lines are the same. I'm looking for the quick disconnect fittings that will work with Aeroquip or Earl's braided fuel lines. Right now I have rubber lines with the original fittings where it connects to the hard line at the shock tower and the quick disconnect fittings at the intake side. Will these same quick disconnect fittings work with braided lines as well? How are the lines attached to the fittings? I know I can get some AN fittings to go with the braided lines at the shock tower side but I'm not sure about the intake side. If anything, I was just going to braze an AN fitting to the quick disconnects. I would rather avoid that though if there's another way to do it. Thanks in advance for any input.
Old Feb 20, 2003 | 07:23 PM
ttt
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
