Took off all smog,how long will cat last?
Old Feb 19, 2003 | 04:56 PM
350 TPI's Avatar
My smog pump hasnt been hooked up for quite some time and i replaced the radiator last night and while i was at it removed the smog pump and all related parts to it.I have ALOT more room.Also took off the A/C since it was burnt when i got it.Anyway i have heard tha the cat will melt or break apart inside eventually causing it to get stopped up.Does that happen gradually or within a few weeks?
Old Feb 19, 2003 | 09:37 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
why are you worried about it? If you took off everything else, the cat ain't gunna make a big difference.
Old Feb 19, 2003 | 09:48 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
yes but like up hear the cat is the only pos that they look at in terms of smog junk in terms of inspection
Old Feb 21, 2003 | 10:47 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
Some cats have an air tube others don't. I've never had a car with a smog pump, but all have had a cat, and some of the cats the air tube is plugged, others don't have the tube on them at all. Smog pump or no smog pump, it makes no difference to the cat. The air tube may make the cat work better is all.
Old Feb 22, 2003 | 11:27 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I read on here somewhere that the cat will clog up. Don't remember what kind of timeframe you're looking at. I too have removed everything except the cats. I think mine are starting to clog. Getting slower sucks.
Old Feb 22, 2003 | 12:00 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
The whole cats clogging from no emissions is just an old wives tale. There have been people who removed it all and in a short time the cats clogged up, so they assumed it was from the emissions deleting. By comparison, there are tons more who [i]didn't[i] have a problem. It would be like somebody who repalced the water pump and a week later the tranny die. So is it safe to say that replacing your water pump will cause your tranny to die???? Think of all the cars out there that have converters but no SMOG PUMP from the factory. Thats most cars and alot of trucks. Look at the LT1s with the electric air pump. GM had so many problems with those pumps, that they found out that they didn't really need them to pass emissions anyhow, so they instructed dealers on how to disable them and update the emissions label to show it was deleted. You'll be just fine.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
BlackFormula
South East Region
Sep 8, 2015 09:59 AM
Stryker412
Sep 7, 2015 09:11 AM
Strick1
Sep 6, 2015 10:38 AM
