Corvette Chip / PROM in F-Body ??
Old Feb 22, 2003 | 11:07 PM
89Formula350WS6's Avatar
Will a Prom for a 1989 Corvette Automatic car work allright in my 89 Formula 350 ??
Both L98 350 's with 700r4, both MAF cars, both have VATS.
What would be the real difference?
I know the vette would have had the aluminum heads and maybe a different gear, the compression difference wouldn't effect the timing that much since the heads are aluminum and don't retain heat as much as iron ones right?
Old Feb 23, 2003 | 11:57 AM
kevinc's Avatar
Car: 1982 Z28
The opposite is true...the aluminum heads can run more timing than iron heads because they don't retain heat as effectively as iron. In some cases, the al heads *need* more timing to get cyl pressure to max as the piston passes TDC.
The main risk of running the extra timing the Vette chip will have on your iron-head F car is detonation damage.
Old Feb 23, 2003 | 12:05 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
From what I have gathered after talking to alot of other PROM burners, a Vette chip will not work. I don't remember the exact reasons, I'm sure if you asked them in the DIY PROM board, they could tell you specifics.
EDIT: Now that I think about it, it might be the Speed Density L98 vettes that I'm thinking about, since they used a different ECM then the F-bodies.
Old Feb 23, 2003 | 04:22 PM
Can a moderator please move this to the DIY prom board for me? Or, should I just repost it there?
Old Feb 25, 2003 | 03:31 PM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
Yes it will work. I use my version of the APYP bin in my 86 IROC. You will have to diasable the oil temp flag in the bin or you will get an SES.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
PurelyPMD
May 5, 2016 04:57 PM
85 Jimmy
Sep 30, 2015 07:56 AM
BLK87Z
Sep 18, 2015 11:29 PM
