injectors
injectors
I i have an 88 iroc with a 305, and im havin the 305 pulled and installing a rebuilt L98 350, and i know with the factory 350 they used 22lb injectors, and my question is would my 19lb injectors and ecm from my 305 work fine with the 350 even though the engine would probably be running lean? any help or answers would be greatly appreciated!
In the speed density years (90-92) the knock sensor and esc. Since yours is a MAF year the ESC is seperate from the ecm, but still needs to be addressed, your fuel and spark calculations will be different from every memcal to memcal, also things car specific like differential ratio's etc.
thejimsterz28
Sep 15, 2015 04:37 PM
