Rubber Fuel Lines
Old Feb 25, 2003 | 07:03 PM
Red88GTA's Avatar
Rubber Fuel Lines
Needing to replace the rubber fuel lines from the Fuel rail to the driver side fender on my L98 1988 GTA. Would like to not use braided unless I have too.
Anyhow, the rubber "Fuel Return" line GM still sells, part number 10068767.
BUT. The rubber "Fuel Feed" line GM has discontinued. This is part number 10096108.
The part number for the "Fuel Feed" line for the 1988-1991 5.0 Vin F motor, the part number is 10113094 and GM HAS this. I got this from http://www.metzcon.com/fbodymanual/images/3-15.gif
What could be the difference between the 5.0 and 5.7 fuel feed lines, they look the same?
Old Feb 25, 2003 | 07:48 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
Why not just take them off, and take them to a hose shop. Get a new set made, shouldn't run you more than $40 bucks, that what I did.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
