Another AFPR Question....
Old Feb 26, 2003 | 09:54 AM
My86TransAm's Avatar
Ok, I need to know if I can adjust the AFPR screw with the plenum on or off, I figure it'd have to be on so you can drive it and see if you notice any difference, right?
Also, do I make the reading with the vacuum hose on or off? ( its the 305, if that makes any difference)
Thanks guys!
P.S- Ok, so it was TWO questions...
Old Feb 26, 2003 | 10:08 AM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
You'll want to dyno test each setting, or at least have some sort of wide band O2 readings to go from. Butt-dyno won't notice the few HP change in many cases. Either that, or do several passes down the quarter to set it...
You'll make the adjustments at idle with the vacuum line off because idle vacuum lowers the pressure during idle otherwise and you'd get false readings on your pressure gauge.
Old Feb 26, 2003 | 11:35 AM
Therein lies my problem, I dont have access to a dyno, theres only one here in utah and its $120 for three pulls. I was planning on put it all back together and going up in 2lb increment before I do a couple passes, put I need to know if I'm gonna have to disassemble it every time I got to adjust it.
Old Feb 26, 2003 | 01:46 PM
Brian'sIROC's Avatar
you won't have to disassemble it everytime. You may however need to make a custom wrench to fit in there. Here's what I suggest: Grind yourself some extra clearance on the plenum above the adjusting screw. If the screw is a standard hex head screw, replace it with a set-screw. This way you can grind down a small Allen key to fit in there and make adjusting easy.
Or just buy the Holley AFPR. It has a thumbwheel that makes adjusting a snap.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
alpine247
Sep 16, 2015 05:25 PM
355tpipickup
Sep 4, 2015 05:32 PM
