Cam needed.
Old Feb 28, 2003 | 03:25 PM
Hung Start67's Avatar
Cam needed.
1992z L98 700r4. Borla cat-back, Hypercrap chip. Looking at the vortec setup, manifold, heads from scoggin dickey. Saw the comment on the ZZ4 cam being a touch small. Car is a daily driver and needs to pass the sniffer. Thanks guys.
Old Feb 28, 2003 | 04:01 PM
jeffsbluez's Avatar
Car: 91 z28
Comp Cams has a cam help line. You can call them at
1-800-999-0853. They have a great selection of cams for our cars Hope this helps. You can also go to www.compcams.com
Old Mar 2, 2003 | 12:28 AM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
may wanna look into the lt4 hot cam, i dont have a 3-fiddy but i hear it is decent and gm cheap (or ebay cheap)
Old Mar 2, 2003 | 06:37 AM
jeffsbluez's Avatar
Car: 91 z28
The LT4 hot cam will have trouble passing the smog test. That is why I did't recommend it. Not saying it can't be done though
Old Mar 2, 2003 | 09:06 AM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
oh, ur right good point
Old Mar 2, 2003 | 10:07 AM
jeffsbluez's Avatar
Car: 91 z28
If you look at the TPIS ZZ9 cam it is nothing more than a revised GM ZZ4 cam..IMHO, and it is emissions legal. It also costs about a hundred dollars more. You combo looks mostly stock(even if you go with the vortec setup) so I don't think the ZZ4 cam is a bit small for a daily driver. I think you will be very happy with the torque the motor will put out. That is what you will notice on the street. The horse power will be good as well but, that isn't what your car is setup for.
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
09ave
Sep 7, 2015 06:03 PM
masonta
Sep 1, 2015 06:40 PM
