5.7 TPI Rebuild
Old Mar 1, 2003 | 01:56 PM
87-5.7iroc-z's Avatar
Car: '87 IROC-Z
Engine: L98 TPI/Possible LS1 swap
5.7 TPI Rebuild
Want to rebuild my 350. Put in a little extra, but keep it computer friendly with no new chips. Completely balanced internals maybe some lighter weight but durable. Going to be everyday driver. Do not believe in trophy cars for myself. Possibly adding on turbo later. Have 87 iroc-z 350 now. Buying 87 Trans Am 350 tomorrow.
Old Mar 1, 2003 | 04:48 PM
88gtagearhead's Avatar
do you want info on internals, heads, or what?
Old Mar 1, 2003 | 06:58 PM
Car: '87 IROC-Z
Any ideas. Want a good smooth running streetable car with a little extra hp for fun.
Old Mar 1, 2003 | 10:29 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
If you are not aiming at the sky then just use you factory crank and rods. Get some KB pistons for now. Have you researched what all is entailed with installing a turbocharger onto a 3rd Gen.?
I would get some Vortec heads with the appropriate base, you only have one choice of supplier right now. Use what ever runners you want, stock TB and plenum are fine. Feel free to port all the TPI stuff if your heart desires. Stay mild with cam, 218* @.050 max duration in my opinion. That is all based on the idea of decent idle, good mileage, all the stuff you mentioned above.
BTW, did you run a search of engine combos?
diana227vegas
Jul 8, 2016 12:27 AM
stalkier
Dec 6, 2015 11:25 PM
fbirdroller
Sep 2, 2015 10:27 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
