350 powerband questions
Ok, a couple of quick questions for the uninformed (namely me
I keep reading about the stock TPI choking the engine around 4500rpms......what would port/polishing and/or aftermarket runners/etc move that point to? What's the best setup that people've found?
)I keep reading about the stock TPI choking the engine around 4500rpms......what would port/polishing and/or aftermarket runners/etc move that point to? What's the best setup that people've found?
Car: Take
Engine: Your
Transmission: Pick
Don't confuse "choking" and "powerband"
"Choking" is when the engine can't efficiently breathe and power DRAMATICLY falls off.
"Powerband" is simpley where peak power is made.
I have seen cars peak at 4400 RPM and die at 4800. My car peaks at 4100, but I can pull up to 5500.
Anything you can do to increase airflow will help push back the point at which is "chokes". However w/ the "tuned" long tube design, your powerband will usually be low.
NinjaNife
Aug 23, 2015 11:49 AM
