just bought an HSR with change I saved up. have a ? though
Old Mar 3, 2003 | 07:12 PM
BOTTLEDZ28's Avatar
Transmission: A4
For all those that have the HSR installed, what things did you find you needed to complete the job. I know this has been asked but I want answers from everyone on everything they needed, The GMHTP HSR build up shows quite a few things but has anyone used more or less or different stuff? also, will i need to buy any O rings?
Old Mar 3, 2003 | 07:17 PM
cobrakiller1989's Avatar
the only PITA i ran into what the fuel line routing....i have the engine out of the car now, so its giving me some down time to play around with new lines. before i just ran temp rubber lines
Old Mar 3, 2003 | 07:19 PM
BOTTLEDZ28's Avatar
Transmission: A4
the fuel line routing is a concrn for me. Does the HSR have a fuel line setup directions? Is there more then 1 way to set up the rails and fuel lines? does the rails get fuel from the front or back?
Old Mar 3, 2003 | 09:02 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Check the sticky at the top. I have the exact same questions as you. It appears the fuel lines connect in the rear for the HSR but I was told I could keep the stock lines intact and buy new fittings. I guess this would require running fuel lines from the new rear location to connect with the existing stock/front location.
Since it's not as clean I guess that's why many are cutting the stock lines at an ealier point and routing them sraight to the back.
Old Mar 3, 2003 | 09:33 PM
BOTTLEDZ28's Avatar
Transmission: A4
I realy dont want to cut my fuel lines in case I decide to switch it out again in th future but I guess if it looks better I have no choice. I just want to be 100% sure that cutting the lines wont make any leaks down the road
Old Mar 4, 2003 | 12:34 AM
Kevin Gray's Avatar
Re: just bought an HSR with change I saved up. have a ? though
It's not a bad idea to get new o-rings for the feed and return line - especially if the stock lines have been removed / loosened and tightened couple times there. I tried to get away with the old ones, but had a mild gas smell under the hood until I replaced them.
Old Mar 4, 2003 | 12:40 AM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
I addressed some of your questions in this thread in case you have not read it.
https://www.thirdgen.org/techbb2/sho...hreadid=163688
86IROC112
Sep 7, 2015 01:37 PM
355tpipickup
Aug 19, 2015 10:02 PM
johanlindgren
Aug 16, 2015 12:16 AM
92camaroJoe
Aug 13, 2015 06:07 AM
