I have a 90 firebird going to TPI form TBI, should I stay with the 89 maf or go SD?
Old Mar 5, 2003 | 11:08 PM
JDV's Avatar
JDV
What I will be doing is getting the complete set up from a 1989 Gta witha 350 L98. Now my car is a 1990 firebird with a 305 Tbi. Should I go with the maf. Or should I just get a speed density wiring harness,and keep it speed density since it is all ready made for that. Because it is a 1990. Will it be easier to make it spped density then it will to make maf? And will I have any problems doing this? Thanks JDV.
Old Mar 6, 2003 | 12:01 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Do a search; this topic has been beaten to hell
Go SD all the way. Much easier to tune, if you do PROM programming. MAF is more flexible to engine modification though.
Old Mar 6, 2003 | 12:07 AM
camaro89RS's Avatar
Go with SD. You already have a MAP sensor that the SD will use that your TBI used.
Jason
xkingcodex
Feb 12, 2020 07:43 PM
NBrehm
Aug 25, 2015 11:49 PM
ezobens
Aug 19, 2015 10:29 PM
Sanjay
Aug 12, 2015 03:41 PM
armybyrd
Aug 10, 2015 09:23 PM
