What size TB should i get?
Old Mar 6, 2003 | 08:51 PM
Project_1986_TA's Avatar
Car: 1986 Trans Am WS6
Engine: Mild 350 TPI
Hopefully verry soon i will have a ported/polished intake manifold and plunem, SLP large tube runners, #24 fuel injectors, Edelbrock headers, and now i need to know what size TB would be good. Right now i have about 275-285hp at the crank. Should i get a 52mm or a 58mm? Check sig for mods.
Old Mar 6, 2003 | 09:30 PM
rezinn's Avatar
Do you have an air foil? You'd probably see more of a gain putting that in than a larger throttle body.
Old Mar 6, 2003 | 09:35 PM
So i should stick with the stock 48mm TB and just get an air foil?
Old Mar 6, 2003 | 09:44 PM
A88GTANotchback's Avatar
Air foils dont do a heck of alot. and the TB prolly is good for a few more HP. .But if u want one get the 52. the 58 is over kill IMO
Old Mar 6, 2003 | 09:48 PM
The 58mm is overkill even with the mods i listed obove? How much of a small gain would i get from an airfoil?
Old Mar 6, 2003 | 10:02 PM
Air foil will get u maybe two hp. for the 40-60 dollars they charge i dont think its worth it. ive seen some home made ones out there that do the same thing and are free. as for the TB i think that with the 58 u need it for 500 plus hp. in ur case the 52 should be more then enuff. correct me if im wrong here boyz!
Old Mar 6, 2003 | 10:31 PM
is an airfoil even woth the price? I found one on Thunderracing.com for $46.
Old Mar 6, 2003 | 11:13 PM
i say no but beauty is in the eye of the beholder. its ur call man. seems like a waste to me. 46 buxs for a fairly minimal gain. Ur choice man
Old Mar 6, 2003 | 11:52 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
its a pain in the ***, but if u really needed to u could have ur throttle body bored over to 50mm, get some 52mm blades out of a v6 throttle body, cut them down to 50mm and ur all set. 58mm is way to big even 52mm is kinda pushin it. 58mm is like a 116mm throttle body! 52 is like a 104mm and the 50mm is like a 100mm. there is another thread in here that has a CFM equation check it out, this will tell u what ur motor needs for air, unless its over 700 which i doubt, u wont need a 52mm throttle body.
Old Mar 6, 2003 | 11:56 PM
I have been doing a little research on them and i am going to get one but im not sure wich one. Im thinking of this one off of yahoo. Air Foil Do you think this one is better than the one off of Thunderracing.com?
Also what does anyone think of TGR Cold Air Intake Kits ?
Thanks for all the replys.
Old Mar 7, 2003 | 12:27 AM
rezinn's Avatar
I think they're both a rip off.
Old Mar 7, 2003 | 12:37 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
that TGR CAI looks like a real hack of a product. i would have expected a lot better peice from them, what were they thinking?hell i could make somethin like that myself.
dude u could make that CAI for like 20 bucks i bet
Old Mar 7, 2003 | 08:19 AM
Dont waste ur money on an air foil and if u do there all the same. everyone does the same thing so get the cheapest one. and the CAI is a pretty shoddy job. go out make urself one. im doing my own this summer. they look easy to do and u'll save urself a wack of money and get just as good results. just take ur time on it
Old Mar 7, 2003 | 10:47 AM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
OK...since no one else has mentioned this yet:
S E A R C H....
There are many threads on this...
Look for one titled "BBK 52 or 58mm"...we hashed this out a lot on that thread...
I would make my own CAI (and intend to) as opposed to paying $150 for that one...
Old Mar 7, 2003 | 11:10 AM
87ColdAirIroc-Z's Avatar
Check e-bay for an air foil if you want one, they are usually going very cheap
http://cgi.ebay.com/ebaymotors/ws/eB...category=33558
Old Mar 7, 2003 | 11:27 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
hell ill pay 5.50 for one!
Old Mar 7, 2003 | 12:25 PM
WinnipegGTA's Avatar
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
I think unless your pushing ALOT more horsepower you really dont need anything above the 48mm, The LT1 305 err 315 HP WS6 used the same size as ours, for that matter so did the LT4 and they were making 335HP. I think you'll be alright.
Old Mar 7, 2003 | 01:11 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
i agree
Old Mar 7, 2003 | 02:16 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Throttle bodies and air foils are both a waste of money. If you really feel the need to waste money, buy the air foil because at least then you'll be wasting less of it. The 48mm throttle body is sufficient until you get well over 300rwhp.
Old Mar 7, 2003 | 06:18 PM
rockind78's Avatar
Ditto.
Old Mar 8, 2003 | 02:29 AM
Ok thanks for the replys.
Old Mar 10, 2003 | 01:36 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I'll have 350rwhp on the motor and and about 500rwhp on the gas. Should I go with a 52 or not?
My buddy has a 58mm on his 355 with Dart Iron heads and stock Manifolds. His car is quick but do you think he is taking a performance hit with such a large TB?
Old Mar 10, 2003 | 08:27 AM
If uve maxed ur mods...the 52 might be ok for u. the factory one can handle quite a bit tho
Old Mar 10, 2003 | 09:01 AM
rockind78's Avatar
Just for reference, the Ramjet 502 utilizes a 48mm TB. I am pretty sure it cranks at least 500 flywheel HP.
Old Mar 10, 2003 | 04:34 PM
But wouldn't an airfoil help just a little bit by smoothing out the air going inside the TB? I have decided to stick with the stock 48mm TB but it makes sense that the airfoil would still help a little bit? Thanks again for all the replys, im learinin a lot.
Old Mar 11, 2003 | 10:43 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Damn i'm in the wrong line of work.$150 for that ****???
Old Mar 11, 2003 | 08:23 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Oh ***, not that again.
Will a 48mm TB support a 500hp 502? Yes.
Would the 502 benifit from a 52-58mm TB? Yes.
Old Mar 11, 2003 | 11:47 PM
rockind78's Avatar
Thank you for reiterating my point.
Old Mar 12, 2003 | 07:07 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
:nono: :nono: :nono:
Still in denile. I tell ya what, the next time I go to the dyno I'll bring my 48mm and my 58mm TB. The only change that I will make between runs will be the TB. I will post the results. I have yet to see a dyno comparison between the two. If you have, please post your findings to support your conclusion.
I think a lot of people rely to much on engine theory instead of real life numbers.
Old Mar 12, 2003 | 01:56 PM
Guest
Guest
Posts: n/a
Good luck doing that one. The plenum really should be setup for the 58mm TB in advance, which will affect the results with the 48mm TB slightly. If you just throw a 58mm on a stock plenum, you are wasting your time.
Old Mar 12, 2003 | 03:02 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Free Bird has a ZZ4 with a comp 306 and a HSR. He can use a 58mm TB if he wants to.
Old Mar 13, 2003 | 01:20 AM
Guest
Guest
Posts: n/a
I see.
Carry on.
Pac J
May 17, 2020 10:44 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
