Idle is not steady...Why?
Old Mar 9, 2003 | 12:54 PM
white91Z28's Avatar
Car: 1991 Camaro Z28
Engine: TPI 350
Transmission: 700R-4
My idle is at 800 rpm and it goes up to 900 rpm. It goes up and down all the time. Is there any way to fix this?
Old Mar 9, 2003 | 04:08 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Guessing here, but try:
Cleaning the Throttle-body/IAC passages
Readjusting IAC/TPS
Checking all vacuum lines for leaks
If you have a MAF, try tapping on
it when idling to see if it gets bad/better.
Put an ALDL scanner on it and see what
sensor readings you have and report back.
mike
Old Mar 9, 2003 | 04:54 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
85MikeTPI did his ususal best in answering your question. I would first look for a vacuum leak. Since your engine last idled smoothly, what have you done??
Old Mar 9, 2003 | 05:12 PM
white91Z28's Avatar
Engine: TPI 350
It allways been like this ever sence i bought it used. I might adjust the TPS.
Old Mar 9, 2003 | 07:42 PM
patrickm00's Avatar
800 sounds too high anyway. i thought they were supposed to idle at 700-1100 when warming up, then 500-600 (depending on year) when in closed loop mode?
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
